Need to get and put user defined properties values (for cogo points)
mehdi-guida
mehdi-guida
Hi
How can i get and put (change) user defined properties values (for COGO points) ?
rl_jackson
First you need to create a new point file format to include the new "attributes" UDP values you want to include. I usually start with my PNEZD file and make a copy and save it as PNEZDA1A2etc........
Define the UDP A1 A2 etc........ this exposes the value in the point file format to the point label style.
HTH
Rick Jackson
Survey CAD Technician VI
mehdi-guida
Thank you for reply.
I have some Cogo points that have property sets. I need to know how can i change their property sets value by lisp.
samir_rezk
Hi @mehdi-guida
Cogo Point User Defined Properties (UDP) are different that Property Sets. Like @rl_jackson noted, you can import and export Cogo Points with UDP if you create a custom Point file format. However if the properties associated with the Point is saved in a Property Set then there is no automated way to modify the points property sets in Civil 3D, but rather we can work with the points using Dynamo to modify or export the Property sets.
many things that we can do with Lisp, can be done with Dynamo! but what would you like the Lisp routine do though? Also, if you post your dwg file or screenshots, it will help the community better understand
Samir Rezk
Technical Support Specialist
mehdi-guida
i am so sorry.that was just a mistake.
My mean was UDP , not property sets.
