Civil 3D Forum
Need to export shapefile with pipe & structure properties (elevation, pipe type, etc.)
5 REPLIES 5
sean_boylanZSLV3
434 Views, 5 Replies
My company is needing to make 3 shape files for storm sewer, sanitary sewer, and water main. Water main just needs location, so elevations don't matter for water, but for storm and sanitary I need to export it with elevations of structure rims and pipe flows. My only idea is to try exporting a gravity pipe network, but I'm not sure if that will give me what I'm looking for. I need property information for the client to be able to use in GIS so they can have a better understanding of what is currently out in the field.
I also need to have data in the properties showing the following information for all pipes:
  • Pipe material type
  • Pipe diameter
  • Structure identity
5 REPLIES 5
Hi Sean,
Welcome to the Autodesk Forums.
Try ExportToSDF.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
I created a document for us to use to do these.  I'm sharing it for you.  SDF is nice but a lot of jurisdictions will only take Shapefiles.  This should help with the process.
Let me know if you have questions, but I am doing training most of the day today.  Thanks.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
If you were to consider third party add-ons, DotSoft's C3DTools will export pipes and structures directly to a ShapeFile with total control over the object properties and can also include Map ObjectData and AEC PropertSet data.
Hi @sean_boylanZSLV3, shapefiles are a specific format by ESRI.Do you use this GIS data in ArcGIS? If the answer is "yes", I would like to complement the idea of using MAPEXPORT that @brian.strandberg presented.
You can publish a series of shapes, including .dwg, .rvt or .ifc files (in this last one, use IFCINFRAEXPORTSELECTED) using the ArcGIS for AutoCAD app available in the Autodesk App Store.
CAD & GIS Integration | Autodesk AutoCAD & Civil 3D | ArcGIS for AutoCAD (esri.com)
Se the how to publish the feature below.
Paulo Santos | BIM Expert | LinkedIn | Contatos |
Automate Civil 3d Elevation Analysis "Heat Maps" with this dynamo script. I have updated the dynamo script for better compatibility with Dynamo Player - check out the link here: https://drive.google.com/file/d/1pcKvde-GYz4ZeIRX4LcOkAyCZQKJammu/view?usp=sharing
Navigate from Civil 3d to google street view. Civil 3d tutorials Autodesk Civil 3d Civil 3d surface Dynamo Visual Lisp
Hi Sea,
Thank you for submitting your question in our discussion forums. I see you are visiting as a new member of the Civil 3D forum. Welcome to the Autodesk Community! Have you had a chance to review the suggestions our experts provided?
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Rail Community
