So I used the grade to surface tool to connect to my EG at a 4:1 slope. The result are parallel contour lines that run till it mets the EG. My problem is that I dont necessarily want it to be parallel, or at least not parallel to the feature line I started from. I need it to be more wavy..
This is how it looks now:
This is how I want it to look (at least not so uniform and parallel to the feature line):
fyi: this grading is built onto of another grading. for example i first graded (using grading tools) 8 ft @ -10% and then graded to surface using the feature line created by the grading.
Ive been checking out grading optimization.. could that help?
