Need lisp routine to create profile from polyline
Sir, there is a lisp for creating a profile from a polyline can i get that lisp...
@BushW has edited your subject line for clarity: PROFILE FROM POLYLINE
Jeew-m
Dear Friend,
You can use create profile from polyline only for gradient objects. Not curves. So first you need to convert the line to tangents. Then manually add the curves. Please refer the video as an initial guide.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
BushW
Hello @Anonymous
I'm just checking in to see if you need more help with this. Did the reply of @Jeew-m provided work for you?
Please hit the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information and thank you for doing so.
Wendell Bush
Civil Infrastructure Technical Support Specialist
hisham_fawzy123
@Anonymous
One of the best solutions to make a best-fit profile, At this link, you can find great video for Jeff Bartels with easy steps to make your profile with best-fit feature
https://www.youtube.com/watch?v=-VE957b29C4
Or You can change the arc areas of your profile from ployline to spline and then use the command convert AutoCAD line and spline a1.jpg
Hisham Fawzy
Civil 3d Certified Professional | Civil 3d Instructor
https://www.youtube.com/HishamFawzy
ahsattarian3
Hello Sir/Madam,
I have written a lisp that does it as in the attached file.
See it and if needed so, I can give it to u.
Regards
Amir
JOKO_
ahsattarian3,
Will you please post the lisp?
Thanks!!
