Civil 3D Forum
Need Help with Dynamo Script
2 ANTWORTEN 2
Nachricht 1 von 3
ToddRogers-WPM
169 Aufrufe, 2 Antworten
This should work, not sure why it's not. Basically, I want to select the structures, then give the value for the surface adjustment. But I can't figure out why this error keeps happening...
Todd Rogers
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
Pointdump
als Antwort auf: ToddRogers-WPM
Hi Todd,
I had to give up on Dynamo, so I won't be able to help, but there is a >>>Dynamo for Civil 3D Forum<<<.
2025.1 has some problems. You may want to try that script with 2024.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Nachricht 3 von 3
essam-salah
hi @ToddRogers-WPM
the SelectObject node is not the right node to select structure, use PipeNetwork.Structures or PipeNetwork.GetStructureByName,
Rail Community
