Need help setting up C3D to use survey codes
Good day everyone,
hope you are winning! 🙂 I'm a Microstation user migrating to C3D and need some advice on how to set it up. My primary goal is to create survey drawings from point clouds acquired with a laser scanner. I'm trying to figure out the best workflow for this. I'm thinking of creating COGO points, coding them, then export as csv and import back in to do the automatic linework. Not sure if this is the best method or not, so would appreciate your advise.
I'm also trying to find the default code list, so I can use it, rather than creating my own from scratch, where is it??
Thanks for taking the time to reply!
Sarunas
Pointdump
Sarunas,
Here's a very good Autodesk University video on Point Cloud Field-to-Finish from Shawn Herring:
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2015/autocad-civil-3d/ci9667/jcr:co...
The Linework Code Sets are found here:
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Dave,
thank you so much for you answer, exactly what I needed.
Kind regards,
Sarunas
