Civil 3D Forum
Naming corridor regions
10 REPLIES 10
Message 1 of 11
dilsmails
1003 Views, 10 Replies
Hi All
anybody has an idea about automatic naming about corridor regions. civil 3D giving the name as
RG - SEC-2 - (1)
RG - SEC-2 - (1) [Copy]
RG - SEC-2 - (1) [Copy] [Copy]
RG - SEC-2 - (1) [Copy] [Copy] [Copy]
RG - SEC-2 - (1) [Copy] [Copy] [Copy] [Copy]
RG - SEC-2 - (1) [Copy] [Copy] [Copy] [Copy] [Copy]
instead of that i need like this or anything same....
RG - SEC-2 - 1
RG - SEC-2 - 2
RG - SEC-2 - 3
RG - SEC-2 - 4
RG - SEC-2 - 5 ( see attached image)
Dileep
10 REPLIES 10
Message 2 of 11
ilia.borisov
in reply to: dilsmails
Check the name tamplate when you create new region
Message 3 of 11
dilsmails
in reply to: ilia.borisov
Thanks for your reply..
This method will work only when you are creating the corridor.
I have some targets for width and elevations. In this case I have to target each region separately. It will take time more than expectationsAfter creating the corridor, and targeting I need to split it as different regions. That time it is naming as copy….copy…copy….copy….
i need to split regions by this methord, any idea to do this the name 1,2,3 etc …. Instead of copy….copy….
Dileep
Message 4 of 11
neilyj666
I don't think it is possible when splitting the corridor; I just manually rename the regions as I go which isn't ideal but works.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 11
dilsmails
in reply to: neilyj666
Thanks Neilyj
Me also doing the same way, what you said. But now I need to design a residential road network which having many parking’s transitions etc.. in this case even one alignment having more than 100  regions. It is hard to rename entire the project corridor regions.
Dileep
Message 6 of 11
wfberry
Does the name really matter?  Select areas in the Corridor with Corridor Properties open and the area is highlighted.
Bill
Message 7 of 11
neilyj666
That corridor properties dialog is going to be a nightmare to manage with that many regions. Is there a more efficient workflow you could use? Do you need to model everything?
Message 8 of 11
davilavanegas
@dilsmails
You could use Dynamo to do this.
Use all this node.
The result should look like this.
Regards
______________________
RDV - Rinat Dávila Vanegas  | LinkedInYouTube | Facebook
Message 9 of 11
ocastaneda
in reply to: davilavanegas
Hi Rinat,
Where can you find decent training materials that show workflows like this in Dynamo?
Thanks in advance!
Message 10 of 11
davilavanegas
in reply to: ocastaneda
Hi @ocastaneda,
https://primer.dynamobim.org/  has good and understanding information for dynamo. Here you get basic concepts.
Autodesk University offer good expo for dynamo, too.
Message 11 of 11
lynn_zhang
Hello @dilsmails ,
Just checking to see if your problem has been solved. Have you tried the suggestion from @davilavanegas using Dynamo? If it works for you, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Rail Community
