My bridge component can't projected into section view
nadifa.aulia98
nadifa.aulia98
Hello there! I have some problem in projecting object on section view.
I designed my bridge in InfraWorks 2021 and then published it (.imx), after that I open my bridge model in Civil3D. I want my bridge model is projected into profile view and section view. There is no problem with projecting object in profile view. But when I tried to project object in section view,  the object (my bridge model) is filtered out... for your information my bridge is not categorized as "3D Solid" or "feature line" or etc. I attached some pictures below as a reference.
Thank you! 😀
**edit
This video is my reference, but he has "3D Solid" exported from InfraWorks.
https://www.youtube.com/watch?v=Ti1g7M1KfLs
igi_pop
Have you tried direct projection to a specific section? As oposed to "project multiple" that is.
I see you've  tried it.
Iggy
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
FhpSilva
Hello @nadifa.aulia98, have you already had a solution to this problem?
apennaUA6ZY
Community Visitor
Community Visitor
Did anyone solve this issue?
chiguichon.o
I have found that C3D has a hard time recognizing any objects other than those listed in the dialog "Project Objects to Section View".  I would try creating 3D lines around your outer portion of your bridge, add the 3D lines to a layer and then it should project that for you.
