multiple sections within viewport
I am sure this is pretty simple, but I am having an issue with it. I am having trouble with my multiple section view being within the viewport when using the create sections sheet. I need to move the start point of the sections to the right and up. The template is setup and "talking" correctly to the multiple section views layout. See attached jpg.
Thanks!
cwr-pae
Unless someone knows a way to have the program read the text limits and not just the grid.
As far as I can tell section views and profile views start at the grid when creating viewports with sheet creation routines. Either move the text in the style to be within the grid or set the default viewport in the template to be just a little smaller than the sheet area you need and adjust the viewport a little after creation.
mathewkol
You need to add a band at the bottom. Make sure it's wide enough on the left to push everything over to the right. Turn off all of the components in the band so they are not visible. The fact that it's there will push everything to the proper place. You won't have to manually move anything.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Thanks for the tip/trick. I got it working.
