Multiple Section Views
CADDVV
CADDVV
I'm working with multiple sections views.  Does anyone know how to move the section view to the right?  How to offset the section view from the print area?  I've attached a picture to try to explain.  The yellow is the print area and the section is in blue.  I'm interested in increasing the area from the lower left of the section. Increase the distance between the yellow and blue in the lower left corner.print area.png
CADDVV
I'm working with autocad 2015.  I think this might have something to do with Sheet styles but not sure how to make it active or how to set it.
doni49
The best workaround that I've seen is to use a blank BAND at the bottom and another at the left to force whitespace in there thus moving the views up and to the right.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
