Multileader orientation in paper space
vmccaw111
vmccaw111
Is there any way to make multileaders made in model space to be oriented horizontally with an alignment in paper space without having to rotate each and every multileader?
I've set the text style to be annotative and to match text orientation to layout, but that hasn't fixed the issue.
user181
Double click to activate the viewport and if the ucs is still on world you can use the UCS command and then choose the View option to rotate the usc to the viewport rotation.  Then select all the multileaders in that viewport and on the properties palette change the rotation to 0.
gregory.luke
What if the multileaders exist in an xref? I see COGO points in C3D can be set up to orientate the text to appear horizontal in a viewport regardless of viewport orientation.
