@jwilliamsZRQUC wrote:
They are sizable. Normally 150MB to 325MB base drawings: 3-4 surfaces, multiple pipe networks, alignments, profiles
Land Development for 800+ homes
I did have 2 days of no crashing. And it's not normally a typical crash where you get the Reporting window - it's catastrophic: the program just goes poof - gone
Those drawings seem excessively large. I'm working on a 12 mile long water transmission main project and our surface file is only 48MB. I worked on a very large airport terminal project where we had 10s of thousands of feet of potable water, reclaimed water, sanitary, force mail, and storm. We separated each utility into its own drawing, i.e., a water DWG, a sanitary DWG, etc. The largest one was the water and it was 14MB in size.
It sounds like you need to use a better project setup. Separate each type of major civil object into its own data shortcut source drawing. I.e, an alignment & profile drawing, an existing surface drawing, existing utilities (separated if lots need to be modeled), proposed corridor, proposed utilities (separated if lots of piping), etc. Use data shortcuts and everything will run very smooth even with large projects. You can also split these files into smaller ones if you're still having issues or need multiple people working on the drawings.
C3D 2024-2026
Windows 11
32GB RAM
