- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a new problem that just started this week. I have a multi leader style that we use to annotate our production plans. We have been using this style for maybe 8 years with only a few minor modifications to the associated block for the tag number. Up until this past week we could use this style with the annotation monitor set to 'on' and never saw the error badge (exclamation point in the box) requiring an associated object. We created drawings from the same dwt that we use for our production plan sheets. The first drawing was just created and shows the proper functioning of the multi leader. The second drawing was created 3 months ago and was working correctly until this week. when the required object association badge raised its ugly little head. Since both drawings started with the exact dwt and the second worked correctly until recently, I am making the wild assumption that there is a sysvar or other setting in the first drawing that has been changed. Here is the link to the Screencast:
https://knowledge.autodesk.com/community/screencast/d03d793d-57a1-4132-8eef-4fdaba6321c8
Any reasonable help would be graciously accepted.
