Civil 3D Forum
mtext adds 90 degrees to my rotation
4 REPLIES 4
gnicholasC4VQN
219 Views, 4 Replies
Every time I type "mtext", then "r" for rotate, pick my rotation with grips, it takes my rotation and adds 90 degrees.  See images.  The test shown in the images, I've clearly asked it to put my text at just over 90 degrees.  however, the text ends up at 195 degrees.  It does this every time I use mtext.  Nothing else does this.  line by bearing works fine. line by azimuth works.  When I click on an existing line, it's properties show the correct rotation.  UCS is set to world.  Typing the rotation in during the mtext command exhibits the exact same behavior.  For example, if I type "mtext", then "r", then "90", the text is rotated to 180 degrees.  I'm at a loss here.
Tags (2)
Labels (1)
4 REPLIES 4
I would check the SNAPANG and see if it is set to non-zero.  Its a weird issue, I'm very curious what the cause is in case any of my people see it.
I spend time on this forum because I enjoy Civil 3d and getting your likes.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Pointdump
in reply to: gnicholasC4VQN
Hi George,
All drawings or just one? Have you tested in a new out-of-the-box template drawing? Can you post a drawing that does this?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Solved the problem.  run the command "units", then click "direction..." at the bottom of that dialog box.  This effectively changes what 0 degrees is.  It was incorrectly set.
ChrisRS
Thank you for reporting the solution.
Christopher Stevens
Rail Community
