Moving View Frame Groups to another drawing
Paul.GrafPZAZ7
Paul.GrafPZAZ7
I have an alignment drawing that contains a view frame group and have already generated the sheets (100+). Is it possible (a workflow) to move the VF group to its own drawing and still retain the sheets?
Paul
Civil 3d 2024
Todd_Rogers
You can create Data Shortcuts with View Frames.
Todd Rogers
Civil Administration
Paul.GrafPZAZ7
The project manager would rather not have the VF's in the alignment drawing.
AdammReilly
Create data shortcuts of your original VFs and then reference them, along with the alignment(s), into a new file. In the new file, promote just the view frames. Once you've done that, remove them from the original file and then remove the data shortcuts.
Adam Reilly
Civil 3D 2026
Creator A16 AI+ A3HVFG
Windows 11 Pro
AMD Ryzen AI 9 365 w/ Radeon 880M
LinkedIn
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
Civil 3D Certified Professional
Paul.GrafPZAZ7
Thanks Adam, would your workflow mess anything up with the sheets that have already been generated? I have over 100 stand-alone sheet files that the PP tools created.
AdammReilly
It should not. The sheets don't retain any links back to the view frames, which is why if you ever change the view frame locations you end up having to recreate the sheets.
This is one of the few cases where that missing link is a benefit 🙂
Adam Reilly
Civil 3D 2026
Windows 11 Pro
LinkedIn
Group Leader badge
LinkedIn | Discord
Paul.GrafPZAZ7
Thank you for the clarification
