Moving pipe up and down. App? lisp?
Joe-Bouza
Mentor Mentor
Joe-Bouza
Does anyone have an app or lisp for moving pipes up or down? currently I use the move command 0,0,0, >> 0,0,<differential>, this is fine for a mass move of uniform differential but I have  many pipes that I have to move up or down with different z values. I don't write much code but it seems simple for a writer: on run: ask for selection and then the amount to move up or down
Joe Bouza
Todd_Rogers
Have you tried it with Project Explorer? Pretty easy operation.
Todd Rogers
Civil Administration at Walter P Moore
brian.strandberg
You can do it in PE explorer by editing the pipe run.
and then...
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Joe-Bouza
Hi @Todd_Rogers
SOLVED!
I have Urbano Visio and all I had to understang is which parameter to focus on.
Civil3d cannot adjust the cover per se, Urbano can. and the start slope. I was able to globally set the start cive to a fixed number then change the hold start slope to x%
BAM! 300 HC adjusted in 5 seconds
Joe Bouza
Joe-Bouza
They are not runs but individual service connections. I want to change the cover value, then the slope.
Joe Bouza
