Moved Section Views Create Lines in Plot
bforr
Advisor Advisor
Message 1 of 8
bforr
I moved some section views to change the arrangement and now when I plot, I get lines from the corridor assemble edges to a point in the the viewport.  They appear in plot preview also.  Anything I can do to fix/avoid this?  Attached are images of paper space and plot preview.
Replies (7)
Message 2 of 8
bforr
oh and while waiting I deleted the section views and recreated them arranging them through the group plot options. i.e. array and plot area.  I still have the lines.  attached.
Message 3 of 8
bforr
and when plotting from model space, same effect. to bottom right of plot view
Message 4 of 8
Civil3DReminders_com
They look light blue, do they happen to be on a plot layer that you can turn off?
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 5 of 8
bforr
wish it were that easy.  Can only see them when plotting.  Can't pick them.  We looked at layer colors.
Message 6 of 8
Jay_B
If any subassemblies used have zero thicknessess, try changing any zero's to 0.0001 and see if that helps?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 7 of 8
bforr
Dang, thought  you were on to something.  I remember other posts about subassembly thicknesses. But alas, it did not fix it.
Message 8 of 8
bforr
well, somehow it fixed itself.  I had tuned of the pivot points in one of my assemblies and rebuilt all corridors and surfaces.  I then went back and turned pivot points back on and it is still good.
