MOVEBAK command back to default
I at one point changed the location of where my backup files save using MOVEBAK. I want to reset this to default, which is the same folder that the original drawing is in.
Does anyone know how to reset this setting to default? I don't want to reset all settings to default, just this one.
Thanks.
rkmcswain
Run the MOVEBAK command, enter "." (a period), press Enter.
Ref: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
If you enter ".", the MOVEBAK folder name is cleared and new BAK files will be created in the original folder.
Thank you
