Modifying corridor code set styles not updating on model space
cyberflow
Advisor Advisor
cyberflow
I dont know why it does this
But when i edit a corridor code set style and one of its features styles and i do apply and save it NEVER updates the display of the corridor.
Why does this happen ?
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
tcorey
Maybe you assigned the new Code Set Style to an Assembly, expecting changes to be reflected in the Corridor? Corridors and Assemblies can use different code set styles. Double check your assignments.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
cyberflow
Oh i'm in a rush right now, but maybe your right il'l check out that to see.
I need to edit the code set style to add something and il'l validate that.
Frank Freitas
LinkedIn
LucasHicks
I've seen this bug on videos and in my own files.  Try a different style, apply it, change back and apply.
OpenRoads Designer, Civil 3D
cyberflow
Hi @LucasHicks
Usually i do that and it works fine, but ... not this time.
@tcorey  I tryed playing with an assembly codeset style, didnt work more
I'm gona tweak my corridor soon gona see if it works
Frank Freitas
LinkedIn
cyberflow
Thank you Tim for the help, in the rush ive forgot to accept your solution
Frank Freitas
LinkedIn
rogersame
this one worked forme, switching code set styles
