modify parcel report
mohammad94sweity
Message 1 of 1
mohammad94sweity
i add the azimuth before but i need more help .
i have cogo point at every start and end parcel segment
i need to modify report like this to add the point number like exactly the image below
and this is the file of parcel inverse
and this is the example parcels
and this the parcels inverse report:
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
xmlns:lx="http://www.landxml.org/schema/LandXML-1.2"
xmlns:msxsl="urn:schemas-microsoft-com:xslt"
xmlns:landUtils="http://www.autodesk.com/land/civil/vcedit"
xmlns:lxml="urn:lx_utils">
<!--Description:Inverse Report
This form lists the direction and distance or tangents or curve data computed from NE coordinates of the endpoints of the parcel segments.
This form is valid for LandXML 0.88, 1.0, 1.1 and 1.2 data.-->
<!--CreatedBy:Autodesk Inc. -->
<!--DateCreated:06/15/2002 -->
<!--LastModifiedBy:Autodesk Inc. -->
<!--DateModified:09/18/2002 -->
<!--OutputExtension:html -->
<xsl:output method="html" encoding="UTF-8"/>
<!-- =========== JavaScript Includes ==== -->
<xsl:include href="LandXMLUtils_JScript.xsl"/>
<xsl:include href="General_Formating_JScript.xsl"/>
<xsl:include href="Plan_Comp_JScript.xsl"/>
<xsl:include href="Conversion_JScript.xsl"/>
<xsl:include href="Number_Formatting.xsl"/>
<xsl:include href="Parcel_Layout.xsl"/>
<xsl:include href="header.xsl"/>
<xsl:param name="SourceLinearUnit" select="//lx:Units/*/@linearUnit"/>
<xsl:param name="SourceAreaUnit" select="//lx:Units/*/@areaUnit"/>
<xsl:template match="/">
<xsl:call-template name="SetGeneralFormatParameters"/>
<html>
<head>
<title>Parcel Inverse Report for <xsl:value-of select="//lx:Project/@name"/></title>
</head>
<body>
<div style="width:7in">
<xsl:call-template name="AutoHeader">
<xsl:with-param name="ReportTitle">Parcel Inverse Report</xsl:with-param>
<xsl:with-param name="ReportDesc"><xsl:value-of select="//lx:Project/@name"/></xsl:with-param>
</xsl:call-template>
<xsl:apply-templates select="//lx:Parcel"/>
</div>
</body>
</html>
</xsl:template>
<xsl:template match="lx:Parcel">
<table border="2" width="100%">
<tr>
<td colspan="3">Parcel <xsl:value-of select="@name"/></td>
</tr>
<xsl:apply-templates select="./lx:CoordGeom"/>
<tr>
<td colspan="3" bgcolor="lightgrey">Area</td>
</tr>
<tr>
<td width="33%">&#160;</td>
<xsl:variable name="ParcelArea" select="@area"/>
<xsl:choose>
<xsl:when test="$Parcel.2D_Area.unit='default'">
<xsl:choose>
<xsl:when test="$SourceAreaUnit='squareFoot'">
<td>Square feet</td>
<td><xsl:value-of select="landUtils:FormatNumber(string($ParcelArea), string($SourceAreaUnit), 'squareFoot', string($Parcel.2D_Area.precision), string($Parcel.2D_Area.rounding))"/></td>
</xsl:when>
<xsl:when test="$SourceAreaUnit='squareMeter'">
<td>Square meters</td>
<td><xsl:value-of select="landUtils:FormatNumber(string($ParcelArea), string($SourceAreaUnit), 'squareMeter', string($Parcel.2D_Area.precision), string($Parcel.2D_Area.rounding))"/></td>
</xsl:when>
</xsl:choose>
</xsl:when>
<xsl:when test="$Parcel.2D_Area.unit='squareFoot'">
</xsl:when>
<xsl:when test="$Parcel.2D_Area.unit='squareMeter'">
</xsl:when>
</xsl:choose>
</tr>
</table>
<br/>
</xsl:template>
<xsl:template match="lx:CoordGeom">
<xsl:for-each select="./node()">
<xsl:apply-templates select="."/>
</xsl:for-each>
</xsl:template>
<xsl:template match="lx:Line">
<xsl:apply-templates select="." mode="set"/>
<xsl:variable name="angle" select="landUtils:GetLineAngle()"/>
<tr>
<xsl:choose>
<xsl:when test="./Start/@pntRef">
Point Number:<xsl:value-of select="./Start/@pntRef"/>
</xsl:when>
<xsl:otherwise>
<xsl:variable name="StartLineNorthing" select="landUtils:GetStartLineNorthing()"/>
<xsl:variable name="StartLineEasting" select="landUtils:GetStartLineEasting()"/>
Point whose Northing is <xsl:value-of select="landUtils:FormatNumber(string($StartLineNorthing), string($SourceLinearUnit), string($Parcel.Point_Coordinates.unit), string($Parcel.Point_Coordinates.precision), string($Parcel.Point_Coordinates.rounding))"/>
and whose Easting is <xsl:value-of select="landUtils:FormatNumber(string($StartLineEasting), string($SourceLinearUnit), string($Parcel.Point_Coordinates.unit), string($Parcel.Point_Coordinates.precision), string($Parcel.Point_Coordinates.rounding))"/>
</xsl:otherwise>
</xsl:choose>
</td>
</tr>
<tr>
<xsl:variable name="Azimuth" select="landUtils:formatAzimuthDMS($angle)"/>
<xsl:variable name="LineLength" select="landUtils:GetLineLength()"/>
<td>Azimuth: <xsl:value-of select="$Azimuth"/></td>
<td>Length: <xsl:value-of select="landUtils:FormatNumber(string($LineLength), string($SourceLinearUnit), string($Parcel.Line_Segment_Length.unit), string($Parcel.Line_Segment_Length.precision), string($Parcel.Line_Segment_Length.rounding))"/></td>
</tr>
</xsl:template>
<xsl:template match="lx:Curve">
<xsl:variable name="angle" select="landUtils:GetCurveAngle()"/>
<tr>
<xsl:choose>
</xsl:when>
<xsl:otherwise>
<xsl:variable name="StartNorthing" select="landUtils:GetStartingNorthing()"/>
<xsl:variable name="StartEasting" select="landUtils:GetStartingEasting()"/>
Point whose Northing is <xsl:value-of select="landUtils:FormatNumber(string($StartNorthing), string($SourceLinearUnit), string($Parcel.Point_Coordinates.unit), string($Parcel.Point_Coordinates.precision), string($Parcel.Point_Coordinates.rounding))"/>
and whose Easting is <xsl:value-of select="landUtils:FormatNumber(string($StartEasting), string($SourceLinearUnit), string($Parcel.Point_Coordinates.unit), string($Parcel.Point_Coordinates.precision), string($Parcel.Point_Coordinates.rounding))"/>
</xsl:otherwise>
</xsl:choose>
</td>
</tr>
<tr>
<td colspan="2" bgcolor="lightgrey">Curve</td>
</tr>
<tr>
<td bgcolor="lightgrey" style="font:bold">Direction P.C. to Radius:</td>
<xsl:variable name="PCtoRadius" select="landUtils:CalculateBearingDMS(./lx:Start, ./lx:Center)"/>
<td><xsl:value-of select="$PCtoRadius"/></td>
</tr>
<tr>
<td bgcolor="lightgrey" style="font:bold">Radius Length:</td>
<xsl:variable name="RadiusLength" select="landUtils:GetCurveRadius()"/>
<td><xsl:value-of select="landUtils:FormatNumber(string($RadiusLength), string($SourceLinearUnit), string($Parcel.Curve_Segment_Radius.unit), string($Parcel.Curve_Segment_Radius.precision), string($Parcel.Curve_Segment_Radius.rounding))"/></td>
</tr>
<tr>
<td bgcolor="lightgrey" style="font:bold">Delta:</td>
<!-- <xsl:param name="Parcel.Curve_Segment_Delta_Angle.format"/> -->
<td><xsl:value-of select="landUtils:FormatAngle(string($angle), 'degrees', 'degrees', string($Parcel.Curve_Segment_Delta_Angle.format), string($Parcel.Curve_Segment_Delta_Angle.precision), string($Parcel.Curve_Segment_Delta_Angle.rounding))"/></td>
<!-- <td><xsl:value-of select="landUtils:FormatNumber(string($angle), string($SourceLinearUnit), 'default', string($Parcel.Curve_Segment_Delta_Angle.precision), string($Parcel.Curve_Segment_Delta_Angle.rounding))"/></td> -->
</tr>
<tr>
<td bgcolor="lightgrey" style="font:bold">Curve Length:</td>
<xsl:variable name="CurveLength" select="landUtils:GetCurveLength()"/>
<td><xsl:value-of select="landUtils:FormatNumber(string($CurveLength), string($SourceLinearUnit), string($Parcel.Curve_Segment_Length.unit), string($Parcel.Curve_Segment_Length.precision), string($Parcel.Curve_Segment_Length.rounding))"/></td>
</tr>
<tr>
<td bgcolor="lightgrey" style="font:bold">Chord Length:</td>
<xsl:variable name="ChordLength" select="landUtils:GetChordLength()"/>
<td><xsl:value-of select="landUtils:FormatNumber(string($ChordLength), string($SourceLinearUnit), string($Parcel.Curve_Segment_Chord_Length.unit), string($Parcel.Curve_Segment_Chord_Length.precision), string($Parcel.Curve_Segment_Chord_Length.rounding))"/></td>
</tr>
<tr>
<td bgcolor="lightgrey" style="font:bold">Chord Direction:</td>
<xsl:variable name="ChordDir" select="landUtils:CalculateBearingDMS(./lx:Start, ./lx:End)"/>
<td><xsl:value-of select="$ChordDir"/></td>
</tr>
<tr>
<td bgcolor="lightgrey" style="font:bold">Direction Radius to P.T.:</td>
<xsl:variable name="RadiustoPT" select="landUtils:CalculateBearingDMS(./lx:Center, ./lx:End)"/>
<td><xsl:value-of select="$RadiustoPT"/></td>
</tr>
</xsl:template>
</xsl:stylesheet>
Replies (0)
