modelling beach
modelling beach
toCR9U7
Message 1 of 12
modelling beach
toCR9U7
I am working as marine engineer and i am trying to model Beach , can someone help me in the sequence :
1- modelling the breakwater on the both side
2- make surface of the breakwater
3- make grading of the beach between
if anyone can help me sample of it
Replies (11)
Message 2 of 12
Joe-Bouza
What does your data set consist of?
civil3d doesn’t care what the surface is. Add the data and breaklines if any
Joe Bouza
Message 3 of 12
toCR9U7
IT consist of existing seabed surface so i have to add 2 breakwater on the right and left
then add perched toe at the end of the both breakwater
then last step is to build the beach but it is tricky and difficult
Message 4 of 12
Joe-Bouza
You have any more information?
Can you share drawing ?
so far your description hasn’t sunk into me. You wasn’t to build a surface out if what? Something must be driving the data set? Points, breaklines, grading criteria, profiles? Sections?
what it the criteria?
what are the limitations?
what is a break water?
Joe Bouza
Message 5 of 12
fcernst
The breakwater can be modeled with a Corridor as a levee trapezoidal structure with oceanic wave freeboard height requirements daylighting down to the bathymetric surveyed surface.. the beach can be modeled with typical Civil 3D grading workflows.
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
Message 6 of 12
fcernst
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 7 of 12
toCR9U7
correct i am using corridor to build the breakwater but when it comes to the beach i have to use grading however i cant solve the interface between the breakwater and the beach
Message 8 of 12
toCR9U7
can you find the schematic drawing , my concern how to model the reclamation and the sand with solving the interface with the both breakwaters
Message 9 of 12
fcernst
Grade the beach first then daylight the beginning X length of the breakwater into proposed beach surface.. the breakwater only interacts with the beach surface at the very beginning for a short while.. then it separates and daylights down to the existing condition bathymetric surface.. unless you’re dredging the bay to create a new proposed bathymetric surface..
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 10 of 12
toCR9U7
I always making the breakwaters first because the beach is always interact with them
Message 11 of 12
Joe-Bouza
This can’t go much further without the drawing to understand
Joe Bouza
Message 12 of 12
toCR9U7
