Modeling depressed curb & gutter at driveway entrance
maikelbRTP8K
maikelbRTP8K
Looking for advice on modeling a commercial driveway entrance (with R40' curb returns and depressed curb & gutter) where it meets a main road corridor in Civil 3D 2024.
Specifically:
- Should the depressed curb transition be handled within the main road corridor (swapping subassembly or using a target over that station range), or modeled separately as feature lines?
- Is the Intersection Wizard appropriate here, or is it overkill for a single driveway condition?
- How do you maintain gutter flowline continuity across the depression?
Any tips or workflow references appreciated. Thanks!
Accepted solutions (3)
AllenJessup
I've always done it with Featurelines to target. But I've seen that it's now possible with transitions.
I haven't watched this but it might help.
https://www.youtube.com/watch?v=NfkjlIe7MkE
Allen Jessup
CAD Manager - Designer
mmichel6UEHA
I guess how I would model the driveway, would be to maintain the region though the driveway on both sides of the road to maintain the gutter. The gutter on that region would be your depressed curb.
I use feature lines for the curb returns, and I am assuming that you have an alignment for your driveway - I would trace your "finished ground surface profile" for your "finished ground profile" (essentially mimics the section of road where your alignments intersect.
this will ensure that if you use a alignment and surface target for your curb returns on your pavement section, you can target your driveway alignment and profile ONLY and omit the pavement section (only model the curb) where it would create chaos and your regions would be crossing.
If you give me a minute, I literally have a project right now that has a similar problem that I haven't graded yet and I can take some snips.
mmichel6UEHA
Let me know if this makes any sense below:
obulesub
Hello @maikelbRTP8K,
It looks like you have received a lot of advice on this thread. Did any of the replies by @AllenJessup @mmichel6UEHA answer your question?
If you are still needing more help, please share an update here. The community will be happy to jump in and suggest more steps to help you get where you need to be.
Best,
Obulesu | Community Manager
deltacoolguy
Specifically:
My thoughts...
- I would do the curb depression in the corridor, precisely because of your last question re maintaining continuity.  Different subassembly, of course.  I have used the corridor in the past to do the driveway apron also, but I prefer to use feature lines for that.
- The intersection wizard is overkill here, IMO.  From what you show it seems pretty straight forward.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
obulesub
Hi @maikelbRTP8K,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
