Hi all. In my attempt to make my life simpler, I made a series of multileader styles for labelling road signage. Each mleader style contains a different block. Each block represents a road sign.
However, changing the mleader style of an existing mleader does not update the block. The block seems to be fixed to whatever style the mleader was originally drawn at.
I am missing a step here, or will this workflow simply not work in AutoCAD? I have tried regen, attsync won't allow me to select the leader.
The mleaders styles I made, each contains a different block
Some of the blocks used in the multileaders
Changing the multileader style does not change the block
A new multileader will use the block
Mike Kingdon
Civil 3D Zealot
