Hi @654work
On command line TOOLPALETTES=>Click the Gear icon=>Select the name of your palette GROUP
If you don't see your Group then you didn't create it properly (or you didn't create one in the first place). To create a Custom Palette Group, go to Customize Palettes=>Right-click in the right panel area named'Palettes Groups'=>New Group=>name & make a new Group
Next, Drag-and-Drop one of the OOTB palettes in the left panel and place it under your new Group. You must have a palette, any ol' palette, to create a New Group. You can delete the any ol' palette later, but for now, your highest priority is to establish your custom group and you can only do that with a 'dummy' palette.
At this point, you may close the Customize window and your Customized Group will contain only one Tab (the dummy tab). From here, you can add additional Tabs, e.g. create geometry tab, annotation tab, block library tab, etc.
Drag-and-drop palettes onto the newly created Tabs. Once you've got the commands on your tabs setup, you can right-click on the 'dummy tab' and delete it.
HINT: Export your custom Group to your desktop or some other 'safe' folder. You can import the saved Group if you ever lose your palette. If you're ambitious, you can customize commands on your palette then email the saved Customized Group to a colleague. Your colleague can then import on his end so he has the same commands. For example, a command for HATCH where you customize the layer, pattern, scale and rotation, so your colleague can apply hatch just like you.
Chicagolooper
