The default panels and parts of my ribbon are missing. Any suggestions for bringing them back? I have attached snipped clips of what my current ribbon looks like.
Thank you.
Solved by ToddRogers-WPM. Go to Solution.
Hi, right click next to an empty panel, say for instance beside the clipboard icon on your home tab. Navigate to show panels and make sure the ones you want are checked.
Hi @Anonymous, type CUI in the command line and click enter.
On the CUI window Customize tab select CIVIL, right click on it and select Restore C3D.CUIX
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
Thank you for your suggestions, all of them are checked. I think the problem is that the options aren't expanded into the toolbar. Any ideas for how to expand them out again in the ribbon?
Thank you for responding, however this is what pops up when I Customize tab select CIVIL, right click on it and select Restore C3D.CUIX in the CUI window .
Your ribbon is semi-minimized. Click the arrow to the right. Keep clicking it until it cycles back to the whole ribbon...
