Misplaced Xref
Misplaced Xref
AllenJessup
Mentor Mentor
Message 1 of 17
Misplaced Xref
AllenJessup
An Engineer created a design drawing and Xrefed the survey basemap. He asked me to create and Acquisition map based on the design. I started a new drawing and Xrefed both the basemap and the design drawing. They didn't line up.
I found the Xref in the Design drawing is shifted. I checked the usual things. Both Xrefs are inserted an 0,0,0 at a 1 scale. The Base in both drawings are 0,0,0. The units and State Plane coordinates in both drawings are the same. "Scale Objects inserted from other drawings" is not checked in either drawing.
Working in a copy of the Design drawing. I inserted the basemap again. It inserted at the "correct" position. I can list both separately and both insertion points are 0,0,0 at a 1 scale. But the new Xref doesn't overlay the first one. The displacement is 2.043'. In the Xref Manager the Xref is only listed once and if I select the drawing in the Xref Manger it selects both versions of the Xref.
I know I'll have to reattach the basemap in the design drawing and move all the design to match. A pain but that's what I'll have to do. But I don't understand how I can have 2 versions of the same drawing Xrefed at 0,0 and not have them line up.
Has anyone seen this or have an idea on how it happened? I'll attach a PDF showing some of the checks I've done.
Allen Jessup
CAD Manager - Designer
Replies (16)
Message 2 of 17
MMcCall402
Any chance there is a XY scale or rotation error in the problem xref insertion that is so small that its not showing up in the limited listed precision. At 600-800k from the origin wouldn't take much to mess it up.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Message 3 of 17
user181
Is it possible the system variable INSBASE isn't set to 0,0,0 in all the drawings?
Message 4 of 17
AllenJessup
Nothing shows within the limits of the program.
                  BLOCK REFERENCE  Layer: "Xref SMSR"
                            Space: Model space
                   Handle = 183f2
       Block Name: "Smsr"
                  External reference
                at point, X=0.00000000  Y=0.00000000  Z=0.00000000
   X scale factor: 1.00000000
   Y scale factor: 1.00000000
   rotation angle: 0d0'0.0"
   Z scale factor: 1.00000000
         InsUnits: Feet
  Unit conversion: 0.99999800
  Scale uniformly: No
  Allow exploding: Yes
Command:
LIST
Select objects: 1 found
Select objects:
                  BLOCK REFERENCE  Layer: "Xref Re SMSR"
                            Space: Model space
                   Handle = 348a5
       Block Name: "Smsr"
                  External reference
   X scale factor: 1.00000200
   Y scale factor: 1.00000200
   Z scale factor: 1.00000200
         InsUnits: Feet
  Scale uniformly: No
                            Space: Model space
                   Handle = 183f2
       Block Name: "Smsr"
                  External reference
         InsUnits: Feet
  Scale uniformly: No
Command:
LIST
Select objects:
                            Space: Model space
                   Handle = 348a5
       Block Name: "Smsr"
                  External reference
         InsUnits: Feet
  Scale uniformly: No
And using Lisp I can check a distance between the two insertion points to 0.00000000000000'
Allen Jessup
Message 5 of 17
AllenJessup
Good thought but both zero out to 8 places.
Allen Jessup
Message 6 of 17
Jeff_M
                            Space: Model space
Jeff_M, also a frequent Swamper
Message 7 of 17
AllenJessup
Good catch Jeff! I should pay more attention. Or get some glasses.Smiley Happy
Now I have to wonder. How did that happen?
Allen Jessup
Message 8 of 17
Jeff_M
Well, it is the inverse of the Unit Conversion Factor listed for the block reference. That should be a clue.
Message 9 of 17
MMcCall402
0.000002 is about 2 feet once you get out to the 600,000/800,000 coordinate range
Mark Mccall
CAD Mangler
Linkedin
Message 10 of 17
AllenJessup
0.999998 is the ratio of the US Survey Foot to the International foot.
But that would mean that AutoCAD (not Civil 3d) is somehow adjusting for International vs. US feet. AutoCAD won't see that the drawings are in the same coordinate system. The AutoCAD Units dialog box now gives the choice of Feet or US Survey Feet. Civil only handles that through the Unit and Zone tab in the Drawing Settings.
Both drawing are set to Feet in the AutoCAD Units. INSUNITS, INSUNITSDEFSOURCE and INSUNITSDEFTARGET are all set to 2 (Feet).
Is AutoCAD now scaling the insertions to somehow account for US Survey feet? If so. How can I stop that? This would account for a lot of problems I've had lately with drawing not quite matching after insertion.
Allen Jessup
Message 11 of 17
AllenJessup
It obviously isn't happening all the time. If I attach the Xref again. It inserts at the correct scale. If I change the scale of the original instance of the Xref. It's in the right place. I was the one who attached the Xref to the Design Drawing. So what did I do wrong and why doesn't it happen when I attach it again.
I can accept that I missed a necessary change in procedure in the 2017 version. I don't want to deal with an intermittent that may jump up to bite at any time.
Another thing that confuses the issue is that is some circumstance both Xrefs list as one entity and in some cases as individual ones. That seems to be based on having highlighted it in the Xref Manager and what commands are used after deselecting it. So it's possible to select the scaled Xref and have the unscaled info in the Properties Dialog.
Allen Jessup
Message 12 of 17
AllenJessup
I was working with Autodesk Support yesterday. They're as puzzled as I am. I duplicated the problem at least a half dozen time and then it stopped for no reason I could see. I had been working with copies of the drawing but when I tested it with the original drawing. I still couldn't duplicate it. This is a shot of one of the times I duplicated the problem.
So I know what happened but not why or why it suddenly stopped.
I checked the UNITS in both drawing and the Insertion Scale is set to Feet (Not US Survey Feet). INSUNITS, INSUNITSDEFSOURCE AND INSUNITSDEFTARGET are set to 2 (feet). AUNITS is set to 1 (Degrees/minutes/second), DIMAUNTS is set to 1, MEASUREINIT and MEASUREMENT are set to 0 (Imperial). The JP2 files are georeferenced in State Plane US Survey Feet. The only thing that specifies US Feet is the coordinate system set in both drawings. But the Xref command shouldn't react to that. Plus the State Plane Zone was the same in both drawings.
I guess this is just something to watch for in the future. I wish I had caught it when the Xref was inserted. I caused quite a bit of difficulty in having to adjust the propose on a nearly completed project.
Allen Jessup
Message 13 of 17
jmayo-EE
This is the new acad unit of us survey feet in action. You may be learning our learning curve for working with the new units. 🙂
What if you set everything to US Survey feet. Acad and C3D?
John Mayo
Message 14 of 17
AllenJessup
Yeah, John. I thought it might be the new unit. But if nothing it either drawing is set to US Feet, as far as AutoCAD is concerned. Where did it get the unit for block insertion. As posted I checked every setting that might affect attaching an Xref.
If both are set to US Feet the insertion would be correct. But it should have been correct with neither of the Units set to US Feet.
Allen Jessup
Message 15 of 17
jmayo-EE
We keep our files unitless and the scale factor is correct also.
John Mayo
Message 16 of 17
AllenJessup
That might be a good idea. I think the reason we have units set to feet in our imperial drawing is that the _AutoCAD Civil 3D (Imperial) NCS.dwt I started our template with has it set. Strangely I checked the _AutoCAD Civil 3D (Metric) NCS.dwt and it has units set to Feet as well.
Allen Jessup
Message 17 of 17
suvas
Just exactly what I was looking for. Couldn't figure out why my xref has been off N-S by 590 feet. When I checked INSBASE, it was at 0,-590,0. I don't know when that happened. Thank you very much.
