Measuring/checking chainage and offset of a point perpindicular to a line
Hi, just wondering whether anyone knows what the easiest way is to measure/check the distance of a point perpindicular from a line (offset) and the distance along that selected line at which it intersects (chainage). So for example I would like to be able to select a line and then click on points either side of the line to give me the chainage and offset distances from that line. I am using Civil 3D 2018 with a Stringer add on. I know that a chainage and offset tool exists in other survey specific programs such as Liscad. I have been using UCS to set the line and then using the coordinates of points to tell me both of these things but I'm wondering if there is a better way.
rl_jackson
You'll need to implement the survey database and use the survey command line to set up a baseline a d then it will inverse the points as you request. Check out survey command line help
Rick Jackson
Survey CAD Technician VI
jroot
Create an Alignment out of the line (or on top of it).
Then in the Inquiry Tool under Alignments, use "Alignment Station and Offset at Point"
lynn_zhang
Hello @Anonymous Welcome to Civil 3D Community!
Just checking to see if your problem has been solved. Have you tried the suggestions from above and did they work? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
bobjiang.au
Do we have any update on this question, please? In survey, checking perpendicular distance from a point to a linework is very common. In Liscad, it is simply one click to a linework and 2nd click to a point.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
