Civil 3D Forum
Measuring average width
2 REPLIES 2
2558 Views, 2 Replies
Is there a way in AutoCAD to calculate the average width between two irregular lines, such as the average width between stream banks?
2 REPLIES 2
sboon
In the past I've been able to get a reasonable approximation using this method.  Start by calculating the average length of the two lines.  Add two temporary lines at the ends to get a closed area.  That area divided by the average length should give an average width.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Didn't think about that. That should get me close enough.
Thanks.
Ron Pemberton | Senior Designer
[cid:image002.jpg@01CDA098.B3326570]
211 Rock Point Drive, Durango, CO 81301
970-426-7005 Direct
ronald.pemberton@urs.com | www.urscorp.com
This e-mail and any attachments contain URS Corporation confidential information that may be proprietary or privileged. If you receive this message in error or are not the intended recipient, you should not retain, distribute, disclose or use any of this information and you should destroy the e-mail and any attachments or copies.
Rail Community
