MDX Micro Drainage Pipe Network Import
Ted.page
Ted.page
i have a Foul Pipe network modelled in micro drainage. I have installed the autodesk micro drainage utility feature. When i execute a file import i get the import options but in the part list, pipe style and structure style drop downs, tehy are empty therefore i cant import the network. Anything obvious im missing?
MikeEvansUK
As you have not suggested which version you are running.
I presume you are using 2017 in which case the tool was (is?) broken and in need of repair.
I understand this has been addressed in 2018 but I'm not so sure about 2017.
Please check you have the latest version of the tool installed.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Ted.page
Hi Mike,
Thanks for the reply. Apologies, new to all this. im running 2018. A quick open of the same drawing on another machine and a reopen on my machine fixed it. Still having a few issues with the micro drainage tool that i have autodesk looking at but is quite frustrating
