Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Jeff’s diagram shows the issue with Civil 3D where profiles, surfaces and corridors are not offset orthogonally to the profile….or a surface is not offset planar normal to the surface plane. The vertical offsets in Civil 3D are not relative to the object plane orientation.. just simply absolutely vertical.
Joe and I interpret the original diagram as 90 degree angles with the triangle height always perpendicular to the base .. no matter the base absolute rotation.
I see the effect that @RobertEVs and @Jeff_M are computing. but this raises another question. if the flow line slope is 2% then the upstream length become 9.1-feet and down stream become 5.9-feet which looks wrong,
Joe Bouza
Hello again,
Depending on what your standard curb height is.
For most projects I have worked on (for 33+ years) the standard has been 6-inches.
if the road vertical slope in not 0.0% (which is not practical for drainage), the ramp lengths will be different lengths (using the 1:12 max slope) or can be different slopes and the same length. depends on who is sealing the drawing.
good luck,
nonbeard13
This discussion has digressed and permutated from the original diagram for isolating and computing x for completing the small triangles at a relative 7.5% within the small triangles workspace domain .. to an absolute 7.5% constraint now for civil grading work. There were no parameter caveats stating this in the original diagram. For example, it originally to appeared to be a simple trick question.. that now the OP doesn’t realize he subsequently posited.
I agree with you. I was only show the it impractical to use the flow line as a basis
Joe Bouza
my understand that slope 7.5% are related with that 1%, and you talking about design profile for something. this is my idea about this, if you create like a profile, and then add labeling for the tangent slope length, then you can get the correct slope length like this.
I agree with you. I was only showing that it is impractical to use the flow line as a basis
Joe Bouza
