Material Volume Table - Length of a Link
camden.n.dean
camden.n.dean
I have a typical cross-section where I'm trying to report quantities from my corridor model. I only want to show the values of the Areas and Lengths drawn on the section (i.e., everything in 2D).
This works well for corridor shapes and their areas, but I can't figure out a way to show corridor links and their length.
Basically, I want to know if there is a way to show the length of the blue line (13.2') in the materials table?
-Camden
nkiakas
Hi @camden.n.dean
It may can be done by using output parameters of your subassembly.
What subassembly did you use?
Can you share your file?
Regards
camden.n.dean
This is all very prelim and simple, so i just built the subassembly from a polyline and added the codes manually. Does that mean there isn't a "smart" way to extract the length of links based on their code?
