mapping file for plot styles
lambertb
lambertb
Here is my scenario. I have a file that is plot by style. I xref a file that is plot by color. Could you set up a mapping tool/layer states/magic spell that would read the xref layer colors and based on this assign a named plot style and lineweight via xref overrides?
And in reverse. I have a plot by color file and xref a named plot file. Could you map the xref lineweight and plot style or layer name to a color that works for the color table?
Thanks.
C3D 2022 and 2024
tcorey
I would probably do it programmatically, but if you don't know AutoCAD programming languages, you can use ConvertPstyles and its related commands:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
