Announcements
Mapimport object data no coming in
Hello all,
Im using autocad civil 3D 2019, and when I use mapimport, I select the file and add the create object data. When I bring it in, there is no data in the property box. I know there is object data, my co-worker can do the same and get object data. Is there something that change that I don't know about?
Replies (27)
Pointdump
Hi Coty,
Welcome to the Autodesk Forums.
Looks like you're doing everything right. Let's look at the data. Can you post your shapefile, or maybe a link to where you found it? (To post you'll need to zip the SHP, SHX, DBF, and PRJ files together.)
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Here is a zip file of our ATWS That we use.
Pointdump
Coty,
I'm getting OD from your shapefile. I can't think of anything I might be doing that you're not already doing. Same as you, I assigned a UTM83-17F Coordinate System.
Select one of the polylines. What does your Properties Window look like?
Dave
Dave Stoll
Las Vegas, Nevada
Here you go.
Pointdump
OK, try this.
Drag-n-Drop that shapefile into your drawing. Command MAPWSPACE will open the Map Task Pane. Select "MVP_AFC_ATWS" and click the Table. Anything there?
Dave
Dave Stoll
Las Vegas, Nevada
Yes sir, there is data in the table.
Pointdump
Well color me totally stumped. How about other shapefiles? Is this the only shapefile with a problem?
Dave
Dave Stoll
Las Vegas, Nevada
Wish it was just this one, it does it on all the other, I tried to go back to older ones, and it still doesnt show the data.
Pointdump
In Options do you have all these Map Paths?
Dave
Dave Stoll
Las Vegas, Nevada
Ok so I do have them, just the 2019 versions tho.
Pointdump
Looks like all your necessary paths are OK. Dang, I can't think of anything else. I hesitate to recommend, but you might need to do a ReSet, Repair, or Re-install. A ReSet is quick and easy if you don't have any customizations.
Dave
Dave Stoll
Las Vegas, Nevada
ChicagoLooper
Please try again. Follow these 7-steps shown below.
Step 4 is critical. Make sure ALL BOXES ARE CHECKED.
Chicagolooper
Ok, I will try that hopefully today, if not tomorrow. I will let you know how it goes. Thank you.
Hello, I have checked that, as shown, I have them selected and still no data. I seen a post on the form where that was the case.
andrewpuller3811
I get this issue when there is an Object Data table already defined in the drawing that has different Data Fields, or in an external reference drawing.
Firstly I would check in the current drawing if the Object Data table has already been defined.
Run the command adedefdata
This will bring up the Define Object Data dialogue.
Click on the Table: drop down and look for the name MVP_AFC_ATWS
If it exists, select it - Click the Delete button at the bottom of the dialogue. (this will delete the Object Data Table Definition)
Try reimporting you shape file
If it is not found, and you have external references attached, open each and run through the same process.
It is a pain when a drawing you attach has the same object data table and you have to go in and delete it. 😞
I hope this helps.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
That seem to work. I deleted the table and mapimport and there is data now. Thank you for the help.
АлексЮстасу
Can you attach dwg with the old OD?
I want to understand what exactly the reason is.
I can't reproduce your problem.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Pointdump
Hats off to Andrew. But I gotta know, how did that table get into your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
andrewpuller3811
One way to reproduce this issue -
Do a mapimport into a drawing with the object data - make sure the imported objects have the data attached.
Save and close the drawing.
Create a new drawing without and data tables.
Attach the first drawing as an external reference to the new drawing.
Do a mapimport of the same data  as import into the first drawing.
The imported object will not have an object data attached.
Andrew Puller
Windows 11
Civil 3d 2023
