Manually setting structure station in pipe networks
I would like to manually set the station of a structure in a pipe network, but the option box is greyed out. I'm looking to set it at an exact station, e.g. "7+53.00" rather than drawing construction lines off that point on the alignment. Is there a way to manually set the structure station? Thank you!
samir.rezk
Autodesk Support
Autodesk Support
Hi @Anonymous
The Transparent tool can help locate the structure at a specific station and offset from an alignment! Select the structure, then click on the grip (as you’d move it) then go to the transparent ribbon tab (available also from right-click menu) find the station offset tool and follow the prompts on the command line to input the station and offset values.
Hope this helps,
Samir Rezk
Technical Support Specialist
That works perfectly, thank you!
