Make s specific Label Style the Default style
Message 1 of 11
I have a specific Label Style which is Point# displayed in Yellow, Elevation in Red, and Description in Green. How do I make that the default Label Style so when I start a new Drawing and import new Survey Points that Label Style is already there instead of having to manually change it each time?
Replies (10)
Message 2 of 11
Pointdump
Marty,
In your Template Drawing, in Settings Tab, right-click on Point. Choose "Edit Feature Settings" and select your Label Style.LabelDefaults.png
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 11
Jeew-m
Dear Friend,
I would like to add little more to Dave's suggestions.
As you said it is a custom label set. So It may not be in your template.
1. First open your template in a new drawing.
2. In the same time open the drawing which you have the custom label style.
3. Then you should drag and drop the custom label style to the new dwg.
https://www.youtube.com/watch?v=x1Rw7yIVpBw
4. Then you can do what Dave's proposed.
5. Finally save this new dwg as a template and use it as the future template. It will contain the default label style.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 4 of 11
Neither one of those made it to where when I open a new drawing and import points the colors are already changed to what I want them to be.
What I would like is to be able to start a brand new drawing and it already be set for: the Point# to be yellow, the Elevation to be red, and the Description to be green, The drawing scale to be set at 20, the Text size and style to be set at L60 and the tic size to be set at 0.5
Message 5 of 11
wfberry
1. Did you make the "PointDump" changes in your Template File?
2.  When you start a new drawing does it load the above template file?
Bill
Message 6 of 11
autoMick
In addition to the above, you can set the default style when the create points command is invoked. Maybe you weren't picking your custom style when you added points?
Civil3d user in Australia since 2012.
Message 7 of 11
No, I'm fairly new to AutoCAD. I took a basic AutoCAD class in school so I didn't learn anything advanced.
Message 8 of 11
That only worked for that specific drawing. When I imported new survey points I had to change everything manually.
Message 9 of 11
autoMick
As the guys above have said, you need to incorporate that style into a template.
Create a new blank drawing and set up the styles you want to have as defaults/available using the settings listed out above.
Then save that drawing as a template (DWT) file. Civil3d will automatically direct you into the default folder to save that template.
Then use the command OPTIONS and point Civil3d to your template for QNEW as per my pic.
Each new document will then open your template, and then if you've set up your default style correctly, and linked it to the CreatePoints command as I outlined above, then your new imported points will automatically be the style you selected.
Regards
Mick
Message 10 of 11
Pointdump
Marty,
Here's a couple of short-n-sweet, cut-to-the-chase videos on Template Creation:
https://www.youtube.com/watch?v=we5BRDUPpZE
https://www.youtube.com/watch?v=sSjmS8zYwIQ
Dave
Dave Stoll
Las Vegas, Nevada
Message 11 of 11
autoMick
Thanks for linking those Dave. I subscribe to Jeff's blog and I reckon they are some of the easiest to watch and most informative videos out there. There would never be a time that I haven't learned something from one of his videos.
Cheers
Mick
