Civil 3D Forum
lower linear work surface 0.0003 m
4 REPLIES 4
Grover_Puma
398 Views, 4 Replies
I want to select the linear work surface and lower it by 0.0003 m, how do I do this?
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
4 REPLIES 4
rkmcswain
in reply to: Grover_Puma
There is a function in Civil 3D to do this. See this.
You could also use the AutoCAD MOVE command and give it a displacement of 0,0,-0.0003
Grover_Puma
in reply to: rkmcswain
Thank you very much for the contribution
Saludos!
neilyj666
I'd love to know what line of work requires this level of precision...!!!!
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
jeff_rivers
in reply to: neilyj666
In a past career I worked on a product line that manufactured nanomovers capable of repeatable positional accuracy of about fifty nanometers.  I think I worked out the scale once, to illustrate how tiny that was: If you were to be shrunk down to the size of a human hair (around 0.003") then the accuracy of the positioners would be, to you at that scale, about the size of one of your hairs.
It was a pretty big leap (in more ways than one) when I entered this field.
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Rail Community
