Lot Grade Generic Subassembly Not Part of Corridor
bforr
Advisor Advisor
bforr
C3D 2026
Built an assembly with a crowned road, a LinkOffsetAndSlope, and a LotGrade subassemblies.  Created a profile view and profile.  Created a corridor. Two things.  The LinkOffsetAndSlope has to be shown as a 25' wide subassembly to be a 15' wide swath in the Corridor.  Biggest deal is the LotGrade doesn't appear in the corridor.
Dwg attached.
Can someone tell me why these two things are happening?  The generic subassemblies sometimes don't work for me.
chriscowgill7373
remember, most of the generic sub assemblies are width controlled from the baseline, not your tie in point, so, if your subassembly starts 10' out, and you specify a 25' wide offset, you'll only get 15'.  So, in the case of your subassembly, you need to specify 35', not 25' because your road is 10' from the baseline, to where the link slope and offset starts.
I've never used the Lot subassembly, but, I think it isnt drawing because it is one of those you have to specify a target elevation for the Edge, otherwise, its trying to attach to elevation 0, which isnt buildable.  If I specify to use the road profile that you have drawn as the elevation target, the linework does draw in for the lot area.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
igi_pop
Hey,
ye, what @chriscowgill7373 said...
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
bforr
I appreciate y'alls reply.  I drew a feature line at the edge of my corridor, offset it the req'd distance, picked it as a target, and it worked, adjusted the elev of the feature line a few times to check how various slopes affected it and it was good.
Thanks again.
