& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
i have an alignment that basically loops around, P shaped. when we put the sanitary pipe in the profile, it goes to a certain point along the P then the pipes go backwards. they are reading the previous stationing. is there a setting that has it read a max dist to the structure to the alignment?
thanks in advance
Your alignment looks 90 degrees to the left and 90degrees to the right. This is a problem when you have a loop. It sees both profiles. We have had discussions of this before. My recommendation is to make more than one alignment, i.e. Sta +00 to 16+00 then 16+00 to 24+00, etc.
Bill
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
