Looking to remove XML reference from survey file
ebattle
ebattle
Good day,
We have a survey file that has been giving us trouble. When we ran an audit on it the panorama shows it's trying to find an xml file that the surveyor used. Is there a way to detach this reference or do we need to go back to the surveyor? We're using Civil 3D 2015.
Thanks for your time.
tcorey
display the triangles
extract the triangles
make a new surface from the triangles (lines).
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Jeew-m
Dear Friend,
This is another method.
Export your surface to land.xml.
In your dwg at the surface properties ---> Definition--> Import Xml file >>set the reference land.xml to your exported surface.
Then the error will no longer appear.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
ebattle
Thank you both for your response...we got it to work,
e
