Locking Points - not working as it should?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm using Civil 3D 2011.
I've been reading through help on this one. In this case, I'm using the Import Points from File (not using the survey database). The help file says if I lock the points (either by right clicking in the prospector, or by using the COGO tab in the ribbon, or 'lockpoints' command)...
from help:
"A locked point cannot have any of its properties changed, including its point style and point label style. It cannot be edited, deleted, or overwritten."
In LDD, if I had duplicate points, I gennerally picked "overwrite" to handle them. Usually there would only be a few control points that were duplicated, and they would be the same every time anyways. I preferred that autocad didn't give these points a new number, so 'overwrite' worked. Regardless, if a point was locked in my drawing, they could not be overwritten, which would prevent various oops's. In Civil 3D, if I pick overwrite, my points get unlocked and overwritten. I find this strange since the help file specifically says this wont happen.
The points are definatly locked. When locked I can not use a move command or make other modifications to the point, but if someone picks 'overwrite' when bringing in additional data, they do not stay locked.
Is there a way to make this locking feature behave more like the help file suggests it should?
Cheers,
Stefan
