Hello @37230778
Yes, @Kyle-L has the right idea.
Here's the down-n-dirty way you can perform to make north point up (it's the same as the @Kyle-L method outlined in Post #6 of this thread).
1. When using Harbeesthoek94.Lo31 Bing Map Hybrid will look like this. See image-1.
Image-1 (Mzimkhulu River and R102, Port Shepstone, SA)
2. Go to Geolocation Tab=>Location Panel=>Click Remove Location=>Yes. Then, on command line =>MAPCSLIBRARY=>Enter. In the Coordinate System Library, do as shown below. See image-2.
Image-2
3. In the Coordinate Section, rename duplicate coordinate system to Hartebeesthoek94.Lo31_B. See image-3.
Image-3
4. In the Parameters section, do as shown below. It may take a few seconds after clicking 'Save' button. See image-4.
Image-4
5. Back in the Coordinate System Library, select the duplicate CS you just created=>Assign button. See image-5.
Image-5
6. Go to Geolocation tab=>Online Map=>Select Map Hybrid. North will now be pointing up. See image-6.
Image-6
This is a zoomed-out view when using Hartebeesthoek94.Lo31. See image-7.
Image-7 (Hartebeesthoek94.Lo31)
This is a zoomed-out view using Hartebeestheok94.Lo31_B or the Duplicate coordinate system. See image-8.
Image-8 (Duplicate CS named Hartebeesthoek94.Lo31_B)
A test point was inserted at Lat -30.739246, Long 30.457613 with modelspace using the Duplicate coordinate system. Both x and y coordinates are positive. The geographic Lat/Long is shown in the Location section. See image-9.
Image-9 (Duplicate coordinate system)
While modelspace was assigned Hartebeesthoek94.Lo coordinate system, a test point was inserted at the same Lat/Long position. In this drawing, the x,y coordinates have the same value BUT are negative. See image-10.
Image-10 (original coordinate system)
Summary:
- If you have received survey data from a surveyor in Hartebeesthoek94.Lo31, keep the original orientation.
- To make your drawing oriented so North is up, create a DUPLICATE of the original coordinate system.
- Then using the DUPLICATE, Draw your points and lines then save it making sure it's saved with the Dup CS and a new name.
- If you must send a drawing with your additions (or revisions) back to the surveyor, open your saved drawing, 'remove' your Dup CS, then re-assign the original coordinate system back to the drawing. Be sure to re-name this drawing (the one using his original CS) a new name so you don't over write your drawing (which uses the Dup CS). The drawing you send back will display Bing Map Hybrid upside down, but that's OK. North pointing down is same orientation as the drawing you received to begin with and it will 'match' your surveyor's orientation and his coordinate system.
Chicagolooper
