LISP to create Civil 3D surface from Point file
hakangus
Message 1 of 19
hakangus
I want a LISP routine that creates a TIN Surface in Civil 3D from a specific CSV-file. Is that possible?
Replies (18)
Message 2 of 19
Pointdump
H,
Well, maybe. I don't know that much about LISP. But I just have to ask you why it needs to be a LISP? You can make a Surface from a CSV file easily and quickly.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 19
AllenJessup
To add to what Dave said.
Allen Jessup
CAD Manager - Designer
Message 4 of 19
hakangus
Point taken!
My reasons are that if I could get some help with that LISP routine, I have an extremely streamlined workflow from database points to a Civil Surface.
Backkground:
We store our height points in an Oracle database. To search them out we draw a polygon, check it in the database with FDO Connection and use it like a boundary. Then SQL creates a CSV file with points that is renamed and copied to the working folder.
That, we have accomplished in LISP and it is a one-button-click.
Wishlist:
The last thing that we don´t know how to do is to create a Surface with a certain CSV file in LISP. If we could do that we´ve made it really easy for our users to do their work.
Message 5 of 19
Jeff_M
Attached is a lisp file that will help with this task. It is setup as a function which can be called from another lisp like so:
(createtinfromfile "E:\\Civil 3D Projects 2016\\Surface.txt" "Test1" "C-TOPO-EG" "Border Only" "PNEZD (comma delimited)")
 where the arguments are: filename surfacename layer stylename fileformat.
Jeff_M, also a frequent Swamper
Message 6 of 19
hakangus
EDIT:
To hasty. Maybe I did something wrong after all. Now it seem to work.
Message 7 of 19
hakangus
Thanks a lot, Jeff! You helped me out once again!
Message 8 of 19
hakangus
Thanks to Jeff (and others) we now have a command that gets point data from Oracle to a file, copies and renames it, creates a Civil Surface with maxtrianglelength set to 5 m. Many thanks to all you people out there helping eachother getting smarter!
Message 9 of 19
BearDyugin
Thank you very much, now on the basis of your code I will try to create a surface of volumes.
Until the end is not sure what it will turn out
Message 10 of 19
erdemcankur12
Observer
Observer
how can I use this lisp on command window.
Message 11 of 19
hakangus
See top post where it says:
I have made a command in the Toolbox easy use but the command line is the same.
Good Luck!
Message 12 of 19
erdemcankur12
Observer
Observer
I take that message.
Message 13 of 19
244311
how can ı use this. I cant. I have to much point files and ı must create seperate surfaces
Message 14 of 19
Jeff_M
Use it just as has been described. Why can't you use it? Just create a new line for each point file:
(createtinfromfile "E:\\Civil 3D Projects 2016\\Surface1.txt" "Test1" "C-TOPO-EG" "Border Only" "PNEZD (comma delimited)")
(createtinfromfile "E:\\Civil 3D Projects 2016\\Surface2.txt" "Test2" "C-TOPO-EG" "Border Only" "PNEZD (comma delimited)")
(createtinfromfile "E:\\Civil 3D Projects 2016\\Surface3.txt" "Test3" "C-TOPO-EG" "Border Only" "PNEZD (comma delimited)")
(createtinfromfile "E:\\Civil 3D Projects 2016\\Surface4.txt" "Test4" "C-TOPO-EG" "Border Only" "PNEZD (comma delimited)")
Message 15 of 19
244311
I have 1.txt and file path :C : \ Civil 3D Projects I edited name, path, layer and penzd but ı cant run
Message 16 of 19
Jeff_M
@244311 Please post your dwg and txt files.
Message 17 of 19
libarraSCXGZ
@Jeff_M is it possible to automatically create a series of surfaces using VLISP, where the origin is 3Dfaces that are on different layers? In other words, create surfaces from objects on different layers.
greetings¡
Message 18 of 19
Jeff_M
@libarraSCXGZ no, the COM API does not have a method for adding drawing objects. This can be done using the .NET API. If you'd like to pursue this please inquire in the C3D Customization forum.
Message 19 of 19
libarra
thank you so much. jeff¡¡
