link grade
trumankiko
link grade
trumankiko
i have my link grade shown at the top of my pave link with arrow direction but every time i export my c3d drawing the arrows do not show. it would save me a lot of time if someone can help me. thanks!
Replies (9)
vantamuct
Could you share your File?
trumankiko
what i always do is after exporting is i select similar all arrows and then change the type of arrow head and then voila all the arrowhead shows up. but in the future i might forget doing this manually so..
trumankiko
this is my file. as u can see there's a lot going on because i am experimenting coz finally i have free time!!! yay mee. i'm looking forward to this day to upgrade my daily process of doing things with civil 3d. hope u'd help me with this one issue. thanks!
vantamuct
Hi, I tried to Export your File with another label style, then i think the problem is about the arrow style, During the export, it is automatically changed to "Closed Filled." , So if you are not want to use exactly the leader with style "Open 30", then change it to "closed filled"
I hope this help
trumankiko
they never show up with any arrow type i use. i always have to select them all and then manually change the arrow type in the properties.
vantamuct
I tried to change the leader style to "Closed filled"  in the style then the "Export" works correctly.
The previous Image is the Result, you may check this File.
trumankiko
ill check this out. thanks!
trumankiko
i tried what u did and it still looks the same. idk why.
vantamuct
Please check your Inbox (Private message)
