LINEWORKSHRINKWRAP creates a new Layer
neilyj666
Mentor Mentor
neilyj666
When using LINEWORKSHRINKWRAP a new layer is created (A-DetailWide-G) and I have no ideo how to stop this beaviour.
2019-04-01 13_31_12-Autodesk Civil 3D 2019 - [L__Tenders_Tenders 2019_E2680 Hartwood Windfarm_2 Tend.jpg
It apparently stems from Layer Keys used in Autocad Architecture but as I don't have this and Layer Keys aren't supported in Civil I'm at a loss to resolve this issue.
2019-04-01 13_37_34-To Shrinkwrap Linework _ AutoCAD Architecture 2018 _ Autodesk Knowledge Network.jpg
Any ideas?
Neil
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Jowennl
Hi @neilyj666 ,
I tested this in Civil 3D 2019 and lineworkshrinkwrap uses the current layer you set before running the command. If you go to layer manager and set to 0. Then using that command will give you 0 layer.
See animated gif below.
Set current layer before lineworkshrinkwrapSet current layer before lineworkshrinkwrap
Cheers,
Jowenn
neilyj666
This is how it had been working but now it is a per screencast
