Linework does not match layer properties when I import survey data
tate.childers
tate.childers
When I import my Survey data and automate the linework, all of the lines are the same color (cyan) and have the same default properties. I have updated my figure prefix database to put all of the linework on the correct layer. When I go to check the properties of each line, it claims that all of the general properties are "ByLayer" even though they clearly are not. What am I missing?
P.S. I have only been using C3D for about 2 months and have less than a year of CAD drafting experience. Please keep that in mind when replying.
Thanks!
rl_jackson
Sounds like you are using the figure style called Standard survey figure, which by default has the color set to CYAN and BYBLOCK.
Rick Jackson
Survey CAD Technician VI
lim.wendy
Hi Tate,
Welcome to the Civil 3D forum. Thanks for reaching out to the forum. Rick is right; by default, the Standard Survey Figure style has the color set to cyan. You can create a copy of the standard style and set the color to your preference. See this video
You can specify default settings for the Survey Figure Style by going to the ambient settings.
Let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
