One of these freaky Friday things. I have to be missing something.
I have a drawing that has Xrefs and Layouts. I have one layer, AQ-PE101, that shows a different lineweight in the layout than others set the same. Here are the layers from the Xreffed Drawing . I've highlighted the three visible in the screenshot below.
Here are the layer setting in the drawing I want to plot from. The only viewport override is the linetype.
And the screenshot with the problematic line shown.
Civil 3D 2017 - SP1.1
Dell Precision T3610, Xeon CPU 3.70 GHz
Win 7 Pro, 64-bit,32 GB RAM, Nvidia Quadro P4000
Samsung SSD 512GB, HGST (WD) 512GB drive
Allen Jessup
CAD Manager - Designer
Allen Jessup
Solved by AllenJessup. Go to Solution.
Never fails. A couple of minutes after posting and the answer becomes obvious. The lineweight in the original drawing was set to 0.0 instead of 1.0. I had found another with the linetype scale set to 0.25. That twigged me to check the line.
I hate revising old drawing to current standards!
Allen Jessup
Allen Jessup
Allen,
Would those also be parcels and could it be attributed to that in some way?
Rick Jackson
Survey CAD Technician VI
Allen,
Rick Jackson
Thanks Rick. I gave up trying to use Parcels for acquisitions a long time ago.
Allen Jessup
Allen Jessup
Hey Allen I recently started using object line weight in the ctb file and find it way better than color dependent.
I'm curious about your screen shot your line weight column has all defaults 0 how does that work?
Joe Bouza
Joe Bouza
Joe,
We definitely have Use Object Lineweight in the CTB. Much easier.
In the screenshot I should have grabbed the headers. The 0's are the Transparency.
Allen Jessup
Joe,
Allen Jessup
Joe Bouza
Joe Bouza
Joe,
The default is 0.010". That hasn't changed in years.
Allen Jessup
Joe,
Allen Jessup
Joe Bouza
Joe Bouza
Joe,
I understand your confusion. It confused me at first, obviously. I've also used CTB's exclusively. At one point we were discussing (fighting over) color standards. Some people complained that they couldn't see certain colors very well on the old CRT's. Mostly yellow and cyan. So I changed the standards so that the CTB was set to plot lineweight By Object. That will default to the Layers lineweight if the entities lineweight is set to By Layer. The layers lineweight can be set to a specific value or to "Default". When I say that 0.010" has been the default for years. I meant that it has been our default for years. the default lineweight is set in the Lineweight Settings dialog box.
All our entities should be set to Lineweight set to "Use Object Lineweight". For some reason the line I had problems with was set to an individual lineweight. Don't know why. But I found some others in the old drawing that were also set individually. So I selected all the AutoCAD entities in the drawing and changed their lineweight to By Layer. If you have more questions. Let me know.
Allen Jessup
Joe,
Allen Jessup
Hi Allen
Thats what had me confused in the first solution. Noe reference to lightweight set in the entities. Now is crystal clear to me. thanks
Joe Bouza
Hi Allen
Joe Bouza
Hey Joe,
Glad you questioned it. I hadn't realized that is wasn't clear in my post. Now going back and reading it. I see that it isn't clear. Now it will be clear to others as well.
BTW: Since you can set the layers lineweight in each viewport. This allows entities in the Xref drawings to be displayed with different lineweights depending on what discipline your working on.
Thanks.
Allen Jessup
Hey Joe,
Thanks.
Allen Jessup
Also CELWEIGHT
Allen Jessup
Also CELWEIGHT
Allen Jessup
