Lines in viewport are not straight
Message 1 of 12
My viewport is not showing the lines straight as these are, in Model and Print Preview these lines are straight but in viewport these are not straight, look like broken. I tried by copying same drawing in new file and there in new viewport in new file but the result is same, broken lines.
Please help if any solution is availble
Thanks in advance
Replies (11)
Message 2 of 12
Pointdump
Muhammad,
I'm just not seeing it. Which of the two JPG's has broken lines?
Two things to try, REGENALL and AUDIT.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 12
troma
Did you do Print Preview from Model or Paper?
Could be a viewport override on the linetype.
(You mean the vertical magenta lines, right?)
Mark Green
Working on Civil 3D in Canada
Message 4 of 12
in print preview it is good, 1st pic is showing in model and in 2nd pic it is in viewport, in model i can see proper straight lines but same i can see in straight in viewport, print preview show also coreect.
Message 5 of 12
Both audit and regen i tried already, by zooming these broken lines changed itself each time, in model and print preview these lines are good but in viewport i can not see them as these are actually pic.jpg
Message 6 of 12
Dwg file is here attached with this
Message 7 of 12
Pointdump
Muhammad,
Yes, I'm getting the same thing as you. Unlocking the viewport makes the problem go away. I don't know what's going on here.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 12
it became a problem for me as i cant work in viewport, the same problem i have on some other files too, anyway if there is no solution then what we can do,
Thanks for your time
Message 9 of 12
I turned off "high quality geometry" in hardware accelerations and it fixed this.
Message 10 of 12
Where I can find 'hardware acceleration' and then high quality geometry in it
Message 11 of 12
You can type graphicsconfig at the command line, or right click on this button in the lower right corner:
When the dialog box comes up, uncheck "High quality geometry (for capable devices)", press OK and you're done.
Message 12 of 12
Thank you very much :), it solved the issue
