Dave!!!! Glad to see you here. As always, thanks for your input.
Hmm!!!! I thought I cleared out all those regapps (these come in from several blocks they use - I've warned them). I must have sent you an older file. I looked at the snapang as a possible culprit, but why would it not be doing this for every line? And I addressed the UCS by resetting it. None of those worked. I ran an audit on the file and it only had one error. I didn't want to purge everything because in their original drawing they won't be able to, but I did anyway and the drawing didn't lock up for me.
I'd like to chalk it up to a corrupt template, but they just started having these issues within the last month. And it's only happening in a few drawings. The weird thing is that it's happening only to a few lines. The only workaround it draw another line over the existing or flatten all the problem lines.
