12:08 AM
Hi all,
I have a very rough TIN surface I've generated with a PNEZ point group, but it's not accurate enough alone to do what I want.
I would like to laser scan the property in question, but I'm not sure what the best product for my need is.
- I considered using a drone since I have access to one, but the terrain is quite hilly and there are a lot of trees.
- The areas I'd like point clouds for aren't very big, and have a low tree canopy so a handheld/tripod supported device seems like the way to go.
- Does anyone have any affordable recommendations for equipment that is relatively easy to use? I am comfortable spending in the low hundreds USD.
- I'm not sure I'll use it a lot, and so would consider renting. Does anyone know if it's easy to find LIDAR scanners for rent?
- Finally, there seems to be a lot of problems with establishing "work flows" around point clouds. I would appreciate any recommendations for direction in bringing the point clouds into C3D. How do I incorporate them into my existing TIN surface?
Many thanks!
