Layout different from printing preview
Hello! I had to apply the command "regen" on my drawing's layout, when I finally make it fit on the layout, and press print, the preview is completely different from the layout, just as if I did not apply the command "regen"
Please, help me
Replies (19)
andrewpuller3811
What settings are you using on the plot dialogue?
Can you post a screen shot of the layout, the plot dialogue and the print preview?
The settings you have in the plot dialogue can drastically change the way the print preview and the print turns out. Getting the settings right can sometimes take a fair bit of trial and error.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
Layout:
And the preview:
ChicagoLooper
You are using a metric template and your plotting settings indicate an imperial size sheet, ANSI A (8.50 x 11.00 Inches). This is not considered a 'best practice' for plotting.
  1. Do you want to draw using imperial or metric units? (Feet vs. meters? Inches vs. millimeters?)
  2. Do you want to plot using imperial or metric template? (Is you sheet size measured in inches or millimeters?)
How you answer will determine the most efficient workflow to achieve resolution.
Chicagolooper
Already changed it, both in the same units, but still not working
ChicagoLooper
Is there a reason why your Paper size indicates, ANSI A (8.50 x 11.00 Inches)? Make your paper size like this:
In your uploaded image (refer to post 3 of this thread), your paper size dimensions are not consistent with the thumbnail preview.
Chicagolooper
Yes, because I was printing in letter paper. Anyways I tried the one you told me, but still not working ☹️
ChicagoLooper
In modelspace, are you drawing in meters? Or Feet?
If you are drawing in meters, then copy all modelspace entities to your clipboard. Open a brand new drawing using the out-of-the-box template named No template - Metric then paste the contents of you clipboard. Go to layout tab and try again.
Chicagolooper
Yes I am. I already did, but still not working. I don't know what's happenig, I did save the document as a pdf couple of times, but  I had to do some changes and then it was not working
The other detail is that if I try to print it from de "model" as a window, it works. Maybe that info can help too.
I'm not sure, but I also think the problem can be related to the "regen" option because everytime I change the scale of the drawing at layout properties, the drawing itself fits perfectly, but the labels get really small or really big and that's when I use the "regen"command to fix the size, and it gets fixed, but when I open the printing preview, labels keep the original size before I apply "regen"
ChicagoLooper
Whin in modelspace are drawing in meters or feet?
Go to your command line and type dwgunits, then ENTER. What does it say on the command line for 'Unit of length <??>
Take a screenshot of the number enclosed in brackets then upload it.
Chicagolooper
ChicagoLooper
Sorry not that. On command line type in dwgunts, then enter, a number will appear indicating Units of length. What is the number on the command line enclosed by brackets. Take a screen shot of the command line.
Chicagolooper
Are you talking about this?
ChicagoLooper
Does your modelspace drawing scale = the viewport scale?
Chicagolooper
If I do that my drawing becomes a mess on the layout, and thats the part where I have to apply "regen"
And If it is not a mess, its to big or too small for the layout page
ChicagoLooper
OK. In modelspace, select an alignment label=>right click=>Select Edit Alignment Labels. Next, do this:
Next, make modelspace drawing units = Viewport scale (see post 16 of this thread).
Chicagolooper
I'm not an expert on this, so I have my concerns. Now the printing works, I can see everthig, but If I make both scales the same, the drawing does not fit on the layout, look the scales I have to use, is that supposed to happen? And also, by making the text that size, I can't read it neither on the modelspace or on the layout, is there a solution?. Anyways now, one problem is solved, thank you so much.
The printing preview, looks good. Everything is perfect sized, not like this.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
